Clicking noises
Old 06-08-2010 | 01:21 PM
puckhead's Avatar
Default Clicking noises
I have a 94 sc1 auto tran that makes weird clicking noises where the e brake is. I think its an electrical issue because it does not start or turn over for that fact. I've jumped the the car and it ran fine with no problems. I let the alternator charge the battery for about ten minutes then shut it off. Went to start it again to make sure it would, the clicking noise under the e brake returned and the same problem occurred. We have replaced the battery, but not the starter because the clicking noise happens even when the key is not in the ignition. Any thoughts on what might be the problem here? We also cleaned the battery cables and they are fine as well.
Old 06-08-2010 | 02:33 PM
trysten's Avatar
Could your alternator be draining the battery?
Old 06-08-2010 | 03:38 PM
puckhead's Avatar
I thought that might be the case but the fact the clicking noise goes on even when the door is shut and the car is off is whats got me confused.
Old 06-08-2010 | 04:43 PM
I believe you just might be hearing the relays from the passive restraint belt system -- you have the shoulder belts that slide back and forth, right?
Old 06-08-2010 | 06:40 PM
indeed the passive restraint control module is under there.
anything get spilled in that cupholder recently?
rjnewt
02-28-2008 10:35 AM
Tman_417
Engine & Internal
10-09-2007 04:04 PM
tbenson82
04-26-2007 01:48 AM
clhawkins74
03-08-2007 09:57 AM
lynn
Saturn L300
09-12-2006 03:10 PM
