clutch adjust 96 sl 1.9 ltr
Old 03-14-2008 | 07:27 PM
BigSmitty's Avatar
How do I adjust the clutch?Had recent tranny work done but now clutch pedal goes to almost floor before I can shift and even then every gear is hard to get into.Clutch was fine before this other work so it must need to be adjusted right?
Old 03-14-2008 | 08:14 PM
Low Saturn's Avatar
There is no adjustment for the clutch. Sounds like who ever worked on your transmission messed up the hydrolic assembly.
Old 03-14-2008 | 08:23 PM
BigSmitty's Avatar
Hey thanks for the quick response,I realized that it is hydrolic so I checked the fluid and it was very low.I added some dot 3 brake fluid and it seems to be coming out of it a little bit.How would he have messed up the hydro assy? Maybe I can look at it in the a.m. when there is light.Thanks
Smitty
john doe
06-05-2013 05:18 PM
gbenderk
04-02-2009 11:56 PM
2000saturnsl2
03-16-2008 05:28 PM
dpellenz
05-18-2007 01:41 PM
