code PO711 97 SL2
Old 01-02-2007 | 07:23 PM
answerman's Avatar
I just changed the ECT and apparently the connector was corroded, cause I fired it up and temp gauge went to half (car was cold). Then it went backa notch beforethe cold mark. I let it warm up a bit but the gauge did not move. I left the car running and wiggled the wires at the connector. The car reved up and then died. I shut the ign off and cleaned the connector. Got it all back together and fired it up again. Temp gauge was at 1/4 mark and car was running great, until the SES came on. I used my EZ Scan 6000 and found Code PO711. Which is (transmission fluid temperature sensor circuit range/performance). I have a pretty good idea of what caused it but I am not sure how to go about diagnosing it. Any ideas would be much appreciated. BTW I have allready pulled the connector at trans temp sensor and got a diff code, so is not the prob. I fear a bad PCM or shorted wire. Thanks
Old 01-05-2007 | 05:59 AM
answerman's Avatar
SEScleared on its own today. Yay. Don't know how, don't know why, SES is gone and I'm a happy guy.
james clark
02-23-2011 10:24 PM
guido
02-14-2008 04:10 PM
ltufd1802
04-30-2007 08:54 AM
mikes 1994 z28
08-09-2006 10:08 AM
chasemi
12-27-2005 03:46 PM
