Computer location
1) Does the engine crank when you turn the key, or is there silence? (Battery)
2) Has the car sat without running/moving for a while? (Maybe a damaged or loose wiring harness eaten through by some varmint)
3) Fuses checked with ohmmeter for continuity, or just a visual check?
See if you can jump it with a larger battery in the donor car -- use good thick cables.
Also check positive cable at battery for deterioration, and neg connection to ground.
When some stuff works and other stuff doesn't it is usually battery or battery related (cables). Usually though, the battery will not be strong enough to crank the engine....
Jumped it and it didn't do any good. Another thing I noticed about the stereo it won't switch stations at all you can adjust the volume but thats all. The thing is just 5 minutes before this happened I was backing it out of the driveway until I knocked over a recycling bin and picked it up and got in started it up and put it in reverse and it died.
Most people connect the jumper cables to the positive terminal of the battery in question, and the negative side to the frame (ground). Technically correct for most issues, but - IF THE POSITIVE CABLE IS BAD, IT WON'T HELP.
