Cruise control and clock light problems
Hi. I have a 1998 SC2 with 133K all available factory
options. I bought it used from a mechanic. I (and the previous owner) have kept
everything stock besides the K & N air filter I put in. The car is in great
shape, gets full power and 29mpg during normal operation. I maintain it very
well. It’s a great car besides two persistent problems.
The cruise control does not work. The controls for it are
mounted on the steering wheel. The LED light for it works. I have even replaced
the control module for it behind the gas pedal out for a re-manufactured
module. Still no luck. Anybody have any ideas and/or fixes?
I have one instrument panel light out. It is the light
behind the digital clock/radio tuner. The clock/tuner itself works fine. All
the other lights work, including the ones for all the buttons on the stereo,
and even the cup-holder lights. I have to turn on the reading light at night to
see what time it is on the clock, and it’s annoying. Did the car just not come
with a light behind the clock or is mine broken? How do I fix it?
Thanks in advance.
well idk about the cruise control. But the clock light might just be burnt out. You should be able to replace it. Just buy a Haynes Repair manual for your year and series. And it will show you what you need to do. Good luck
