Drastic decrease in MPG
Old 02-18-2009 | 10:16 AM
ryan@waggs.net's Avatar
Hey guys,
First off I want to say that I bought my 98 sl2 (manual) slightly out of desperation for a car, about 6 months ago. It now has about 143k on it. I have fallen in love with it. I am not a mechanic, but armed with a manual and a tool set from sears, I do what I can. I have been doing things to my Saturn that I didn''''''''t really need to do. Changing things like the alternator, starter, and brakes, before I really had any problems. I was just kind of trying to learn about my car etc.
Anywho!
I was probably getting about 28 mpg, driving 30% highway. I was pretty happy. Recently, however I have dropped down to about 21 mpg, and driving habits haven''''''''t changed.
I did small things like air filter, plugs, cable etc. with no change. I did recently do the back brakes, and I need to double check them to make sure the wheels are spinning, but I remember doing that when I put the wheels back on.
So, assuming my brakes aren''''''''t the cause, are there any other ideas?
Thanks!
Edited by: ryan@waggs.net
Old 02-18-2009 | 04:45 PM
ETC sensor and connector
Old 02-18-2009 | 05:41 PM
sw2cam has the answer, and oh, by the way, I sinserely hope you did not put platinum plugs in your engine ...
Old 02-18-2009 | 09:24 PM
Cool! I''ll go ahead and get started on that.
While we are on the subject, are there any tune ups or particular parts
that can help mpg at all?
Thanks guys!
Old 02-18-2009 | 10:41 PM
A can of throttle body cleaner and a new set of plugs might help. Be sure to coat the threads with anti-sieze, and DO NOT USE PLATINUM
Old 02-18-2009 | 10:53 PM
ok, ok i''ll say it...
what''s wrong with platinum? [img]smileys/smiley12.gif[/img]
Old 02-18-2009 | 11:30 PM
The spark system on a Saturn is not designed to operate with a platinum plug. Poor performance, rotten gas mileage just to name a few ...
Old 02-25-2009 | 07:31 PM
Seemed to work wonderfully.
Thanks guys, i''l have to make another thread with a new problem if I
don''t find it searching.
Ttyl
Old 03-10-2009 | 09:14 AM
Kdrum25's Avatar
wow am i sure glad i just read this post! i have a 98'' sl2 5spd and i bought mine too out''ve desperate need for a car. Mine had 149K mi on it when i got it in July 08'', now it''s up to 152k. But anyway, i''m getting ROTTEN gas mileage. [img]smileys/smiley6.gif[/img]I have a new air filter, new tires, new brakes (fr & rear), oil recently changed, new plug wires, new battery, new front axles, new wheel bearings, new clutch, new shift cables and even a new shifter with a boot!! STILL bad. and to make matters worse, i put Bosch Platinum plugs in it maybe a month ago![img]smileys/smiley3.gif[/img]I didn''t know you weren''t supposed to! Does anyone haveany suggestions on what type of plug works best? Thanx so much for any info!
~Krissy~
Old 03-10-2009 | 12:29 PM
Buy your plugs from the SATURN dealer then you''ll be sure to get the right ones.
