Engin temp
Engin temp
The temp on my 96 sl2 runs much hotter than befor I changed my ects witch I did because the old one was the original plastic one and the idel was stating to become affected the car always ran at the 1/4 mark changing the senser fixed the idel problem but know the car runs hotter why?
pleas help
pleas help
Runs hotter
U are right I got the sensor from auto zone how is it different from the dealer. I did call A dealer to see if there's was different or like the original but they were unable to say. I also have read on this site that the various models run at different temps but as this is the only deviation from the 1/4 mark it seems unlikely that it should run hotter now right? How can the sensor make it run hotter it reads the temp it dose not regulate it. Have u herd of this happening before?
Thank u for Ur help
Thank u for Ur help
Well I got the ects from the gm dealer and it dose nothing different if the sensor is thinking the car is hotter then it is how come it dose not kick on engine fan
Why dose simply changing this sensor Chang the engine temp what should i do ?
The word is. "does"
The temp does not change. The proper etcs or the one from GM is calibrated correctly so the reading on the temp gauge shows as GM intended.
Again the cooling fan should not turn on till you get to about the 3/4 mark A/C off. Fan should be on at ALL times with A/C on. Thats if the damn fan is working in the first place, and you have no idea if it works or not.
thatsreality
04-09-2007 03:43 AM
