Engine Code Help!!
Old 08-07-2008 | 07:28 PM
bigdezy419's Avatar
Ok so today im driving my 2002 Saturn SL1 and the service engine soon light comes on. I drive it to my mechanic and he uses his computer and it says its pulling 2 codes one is:
P0128
and then the other one says P0128 pd..
Ive looked around on the computer and ive seen something that says Insufficient Heat? help me out please. thanks
Old 08-09-2008 | 12:22 AM
Did a bit of poking around on the net. . . .
PCM is sensing that the coolant temp is not reaching a high enough temp within a certain amount of time after start up.
So I suspect either the ECTS is giving a low temp reading to the PCM, or the thermostat is malfunctioning and the coolant in fact is not heating up as quickly as it should.
Have seen quite a few posts on this elsewhere for Vues but not the S cars.
ECTS failure usually comes with all kinds of other bonuses, like hard starting, crappy fuel economy, bogging under acceleration, etc.
Guessing the thermostat, but check ECTS first anyway.
codyj88
01-07-2013 03:06 PM
james clark
02-23-2011 10:24 PM
Curly
04-04-2010 07:28 PM
Mike1288
05-23-2008 05:32 PM
mikes 1994 z28
08-09-2006 10:08 AM
