Fan won’t come on
Old 06-04-2008 | 10:17 AM
vslap's Avatar
I have a 2002 SL2 that is overheating. The temperature guage is moving into the red in traffic but drops back down when moving. The fanis not coming on even when the A/C is turned on. By looking at the posts on this subject it looks like it could be a fuse, a relay or the fan motor itself. Where should I start?
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old 06-04-2008 | 03:08 PM
vslap's Avatar
Never mind...the fuse and relay for the fan are under the hood close to the battery in the black box labeled "fuses and relays." (lol) The fuse looked good, switched relay out with air pump relay turned on A/C still no fan. Replaced fan motor. Problem fixed. Edited by: vslap
Old 06-05-2008 | 10:36 AM
Low Saturn's Avatar
The fan motor doesnt go out for no reason. Check your temperature sensor and its connector to make sure it not causing the fan to run when its not supposed to.
Tuscoro
08-17-2014 11:33 PM
jackers3
07-26-2009 11:53 AM
radar2k
05-01-2009 07:19 PM
saturnl300
Saturn L300
09-06-2008 01:31 AM
Slick2005
Engine & Internal
11-02-2005 02:02 AM
