Fault code P0711
Well my booklists the following:
P0711 ...Transmission Fluid Temperature (TFT) Sensor Circuit Range/Performance Error
Sounds to me like you have a temperature sensor that has gone bad, or that the wiring for it is defective.
This sensor feeds directly to the section of thePowertrain Control Module (PCM)controlling shifting mode and performance, so it is quite likely that the two issues are related.
mikes 1994 z28
08-09-2006 10:08 AM
