fuel pump replacement
Old 03-19-2008 | 11:46 AM
alvinc's Avatar
How do i replace the fuel pump in a 2001 saturn s series
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old 03-20-2008 | 10:21 AM
Low Saturn's Avatar
Lift the car, remove the tank, remove the pump assembly. Reinstall in reverse order.
Old 03-20-2008 | 10:38 AM
alvinc's Avatar
thanks. also would that prevent the car from starting or how can i make sure its the problem
< =text/>
urchinTracker();
Old 03-20-2008 | 11:40 AM
Low Saturn's Avatar
Its possible. Do you hear the pump prime when you first start the car? Is there fuel coming from the test port?
Old 03-20-2008 | 12:17 PM
alvinc's Avatar
where would the test port be located? and i dont think i do hear it prime should i be listening from the rear or under the hood for that
< =text/>
urchinTracker();
Old 03-20-2008 | 01:22 PM
Low Saturn's Avatar
The test port would be just before the fuel rail. You should be able to hear the pump prime from inside the car. As soon as you turn the key to the run position (without starting the car), you should hear hum for a few seconds.
Bill Berger
06-12-2014 02:32 PM
CSRKL1
02-25-2013 07:45 PM
95saturnSL1
09-08-2009 11:40 PM
98SlammedSL2
11-22-2008 06:50 PM
Indica
09-27-2007 09:22 AM
