gas pedal
Old 02-18-2009 | 10:35 PM
dtone90's Avatar
my gas pedal is sticking any suggestions how i could fix it
Old 02-18-2009 | 10:45 PM
Replace the throttle cable. Use OEM part here, as the after-market part will not hold up to the environment, and will corrode/freeze up
Old 02-18-2009 | 10:47 PM
Are you sure it the pedal? Are you sure it''''s the cable? Are you sure? ..... Ah hell don''t try to figure it out just go buy parts till you find the right one.Edited by: sw2cam
Old 02-18-2009 | 11:22 PM
Arrggghhhhh ... there I go jumping to conclusions again. My bad.
Of course, SW2cam is right, the sticking part may be the pedal, and not the cable itself ...
Old 02-20-2009 | 12:33 AM
ASKBCG's Avatar
My Pedal stuck a while back, but it was only in the idle position. It was easily resolved by cleaning the throttle body. I''d check that
Old 02-22-2009 | 05:30 PM
Originally Posted by ASKBCG
My Pedal stuck a while back, but it was only in the idle position. It was easily resolved by cleaning the throttle body. I''''d check that
Cleaning the throttle body ........ thats the first thing I''d do.
A can of fuel injector cleaner in a spray can does the trick.
Old 02-24-2009 | 08:08 AM
Did you clean the throttle body yet?
Rschriner17
02-07-2014 10:50 PM
brendastgermain
11-27-2013 04:33 PM
krazy Dan
02-02-2013 09:07 AM
Jerm088
05-21-2009 12:17 PM
nhughes18
03-06-2008 11:45 PM
