Grommet Location for Valve Gaskret?
Old 12-28-2008 | 10:35 AM
jmayers's Avatar
I have a 97 Saturn SL. I replaced the valve gasket and was left with two grommets that were not used. Could someone please help me find where these grommets are located I think I found one but am not sure. Thank you in advance.
Old 12-28-2008 | 11:01 AM
Jmayers -
Did you use an OEM gasket set, or an after-market product?
Describe your left over parts more fully, please ...
Old 12-28-2008 | 01:28 PM
Low Saturn's Avatar
They go where the bolts go through the valve cover. Since you have a SOHC, you only have two. They usually get stuck to the cover, with the washer on top during removal.
Hopefully you got a preformed gasket and not those stupid kits that are the grommets and a tube of RTV.
Old 12-28-2008 | 02:22 PM
jmayers's Avatar
The only thing they had was the kit which is exactly what Low Saturn stated, a tube silicone and two grommets. I used the silicone but could not find where the grommets go.
Old 12-28-2008 | 07:33 PM
Low Saturn's Avatar
I''d remove all that RTV and install the correct gasket kit.
When you remove the bolts that hold down the cover, there will be two big washers and two grommets underneath.
celeste
07-11-2010 05:46 PM
ds28
05-21-2008 10:46 AM
iveyx001
11-08-2007 08:03 PM
floridaboy32905
04-27-2007 01:31 AM
mjeltema
11-03-2006 10:33 PM
