Heating issue=/
Old 06-05-2008 | 04:35 PM
jisnut's Avatar
To start out, its not over heating well i think. My dad said the temp gauge should read a lot hotter than it does. He drives 20 miles to and from work and its hot. Idk if the sensor is messed up for the gauge. Or maybe a miracle occured and my car doesn''t heat up lol jk. Any help is much appreciated. Thanx
Old 06-05-2008 | 04:45 PM
Low Saturn's Avatar
Probably the coolant temperature sensor. When they go bad, they usually give a false low reading. And cause the car to waste a lot of fuel as well.
Old 06-05-2008 | 06:12 PM
jisnut's Avatar
well that would explain the crappy millage. Thanx.I''ll check that out tomorrow.
Old 06-09-2008 | 12:55 AM
Barmitch's Avatar
Originally Posted by jisnut
To start out, its not over heating well i think. My dad said the temp gauge should read a lot hotter than it does. He drives 20 miles to and from work and its hot. Idk if the sensor is messed up for the gauge. Or maybe a miracle occured and my car doesn''''t heat up lol jk. Any help is much appreciated. Thanx
Old 06-09-2008 | 12:57 AM
Barmitch's Avatar
The guage normally reads about 1/4 inch over the left hand side mark on the guage. I thought mine was cold also, but this appears to be normal.
Check Temp sender as advised
Check Thermostat (might be stuck open)
Check fan not stuck on
ForgottenOne
01-03-2010 09:37 PM
ForgottenOne
10-19-2009 10:00 PM
supertrucker197
01-05-2009 08:15 AM
SL2 pirate
05-09-2008 10:33 AM
kingvandal
01-09-2007 05:31 AM
