How do i replace the timing chain gasket on a 98SL1
Old 01-27-2010 | 05:41 PM
alex_0227's Avatar
Default How do i replace the timing chain gasket on a 98SL1
I just replaced the valve cover gasket and realized that the gasket on the timing chain cover needs to be redone aswell. How would I do that? Is there a good article out there about it?
Thanks
Alex
________
VOYEUR SPY
Old 01-27-2010 | 10:30 PM
hoseppi's Avatar
. It is silicone except for the crankshaft seal. You just have to take the cover off,clean both surfaces, and apply a bead of silicone on the cover. Are you sure it is leaking, because that's usually a fairly reliable seal. The crankshaft/vibration damper seal, however, does occasionally fail. It can be replaced without removing the timing chain cover.
jgroup
06-17-2014 05:52 PM
Classof84
01-12-2008 06:55 PM
95_SL2
01-06-2008 10:51 PM
hartman
04-03-2007 02:14 AM
hbtdawgs
02-08-2006 06:39 PM
