I have a ’99 SL that misses on accelerati
Old 03-10-2006 | 11:44 PM
nuwt's Avatar
ok, I have replaced plugs and checked fuel pressure. it is at 47
pounds. I sprayed carb cleaner and checked for vacumn leaks all around
including intake. I have a fresh tank of gas with seaform additive and
it still missing/jerking. It is gettting worse tho, idles fine, runs
fine, just acts up on acceleration and worse under 2000 rpm's. it doesnt jerk or miss when it is floored. I pulled each wire
off and there was a noticeable difference in the rpms each time.
any other ideas?
Old 03-16-2006 | 12:11 AM
rchinny's Avatar
i am not a mechanic but i had a similar problem and it was the fuel injector....has any warning lights come on..ex check engine
Old 03-16-2006 | 04:30 PM
ottjoe88's Avatar
coil pack is bad
Old 03-16-2006 | 07:34 PM
nuwt's Avatar
Well, It was bad plugs. 2 of the 4 i bought was bad, So after replacing plugs again It runs smooth and fine!
Blue
05-08-2016 09:43 AM
jmc8338
09-20-2011 05:09 PM
taylor
03-08-2008 09:20 PM
delorean004
02-29-2008 12:40 AM
sl1driver
01-09-2008 10:16 PM
