Key Stuck. Can't Shut Engine Off.
I started the car, but now I can't turn the key back and shut off the engine. The engine is still running. Is there anything i can do?
It's a 92 Saturn SL1 automatic
You might try LIGHTLY tapping on it with a hammer. IF that doesn't work, just disconnect your battery ground cable. If that does work, try putting some graphite in the ignition cylinder and rotating the key back and forth a few times. This will lubricate the tumblers in it.
See if you can find a kit with the removable tabs for your original switch. You simply disassemble the old one, one tab at a time, clean off the old one and check the # or letter on it and put in a new one with the same # or letter. After you get them all in, your old key should still work in the switch. If you can't find a kit like that, then you'll just have two keys on your key chain, instead of one.
