Losing Gas Mileage?????
I normally run about 400 mile to a tank of gas, I have a AT 01 SC2 with 35,000. Just recently i've lost gas mileage, I now get about 200 to a tank. My car also is idling at 2000 every once in awhile.. What can be wrong?
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
Alot of things. your car could be getting the wrong mixture of air and gas. have you gave it a tune up? =oil, oil filter, sparkplugs, wires ect ect. It could be the idle speed got messed up, which is an easy adjustment on older cars any way. Also i went from 350 miles down to about 200. Then I took a trip by plane came back tripometer said 149 and i had half a tank. burned the rest of the gas filled it up went to reset the tripometer and it was still at 149, now whenever i reset it it doesn't go past 9/10 of a mile. so bump your miliage with your odometer also.
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
when was the last time you changed your airfilter that has ALOT to do with gas milage
