Nocking noise when AC is turned on
Knocking noise when AC is turned on
I have a 99 Saturn SL2 that has a Knocking noise when I turn on the AC. When I turn off the AC, the Knocking noise is gone. Any Ideas?
sounds like a locked up compressor. If you have mechanical ability slip the belt off and give the a/c compressor a turn. If the clutch is catching or completely locked up then you will need a new compressor.
jcoll72305
01-24-2013 10:45 AM
2000, 99, ac, air, belt, compressor, conditioner, knocking, noise, noisy, replacement, saturn, sc2, tensioner, turned
