oil leaking into spark plug holes
So the original gasket failed after12 years I''d say you got your money''s worth out of the original.
Did you ensure that both the head and the cover surfaces were clean and free of previous gasket material?
If it''s just oil in the spark plug wells I''m betting you just didn''t use enough RTV in the circular valve cover grooves that surround the wells when installed. I wouldn''t skimp on the RTV at these locations. When you pull the cover it will be easy to see where the oil leaked from.
Signed,
BeenThereDoneThat
Signed,
BeenThereDoneThat
