oil mixing with antifreeze?
Old 11-03-2010 | 10:07 PM
skorger's Avatar
Default oil mixing with antifreeze?
i have a 1994 saturn SL1 and it i keep finding oil mixed in with the antifreeze yet no leaks and no loss of oil from the engine, and cuases serious bogs while driving, suggestions please.
Old 11-03-2010 | 10:23 PM
blown head gasket or cracked/porous head. if oil is in with the antifreeze, there is likely antifreeze in with oil -- it will be milkshakey. Level will seem fine but things are definitely not well
Old 11-03-2010 | 10:24 PM
skorger's Avatar
possible cost of fix?
Old 11-03-2010 | 10:29 PM
maybe $700 for a head gasket
head from junkyard engine -- not sure -- check the net
if head gasket ---compression test will localize problem to one or more cylinders
if crack in head or head is porous, may be more difficult to locate
Old 11-03-2010 | 10:32 PM
Hmmmmm --
If it's a head gasket, probably about $325usd. If the head is cracked, probably about $525usd. You can save a portion of that if you do the work yourself, but I don't know your level of expertise ....
Old 11-03-2010 | 10:37 PM
thanks for the financial corrective action, OA
Old 11-03-2010 | 10:39 PM
Hey - no problem .... we do things more inexpensively here in the South
95supersaturn
01-14-2007 02:17 PM
henrylford
09-17-2006 05:58 AM
