ordered my reprogrammed ecu from JET, 94 sw1
Old 09-01-2009 | 04:27 AM
bucky katt's Avatar
Default ordered my reprogrammed ecu from JET, 94 sw1
well, in addition to the rebuilt bottom end, refurbed head and removal of the cat, i just sent out a spare ecu to the folks at JET for re-flashing. i'm hoping that this will help the part throttle power (so the trans doesnt constantly have to kick into a lower gear with the cruise control on while on the interstates) i'm also doing a small amount of intake and exhaust port cleanup, not hoging the ports out just cleaning up the casting flash and i've put in a set of high-flow valves. the last thing i need to do, and it will wait till the present tires are worn out, i'm going to either a 15 or MAYBE a 16 inch rim. any idea how much of a difference that ecu re-flash will make? i was also wondering if there is a heavier front sway bar and a rear sway bar made for these cars?
Last edited by bucky katt; 09-01-2009 at 04:29 AM. Reason: needed to add another question
Old 09-01-2009 | 06:51 AM
what are they reflashing it to? As far as I know, there's not a whole lot of tuning you can do on the S cars via the PCM....
As for sway bars -- dunno-- never tried to hunt them down
Old 09-01-2009 | 02:18 PM
saturnsdn's Avatar
from what I've heard it sounds like only one place sold upgraded sway bars and they've been discontinued due to low sales so probably the only way to get your hands on them is watch ebay, look around in jys, maybe craigslist or forums like this.
only option you have since you have a sw1 is use the sway bars out of an Sx2
99turbo
09-10-2009 11:04 AM
93sl2
08-21-2008 06:48 AM
lilsizfly
06-18-2007 08:40 PM
jameswemm
05-12-2007 04:32 PM
lilsizfly
05-12-2007 04:29 PM
