Overheating amongst many repairs help please
Old 09-19-2009, 05:14 PM
PdPuNOme's Avatar
i hope it is just the water pump thats only a $32 fix. there is water coming out of the tailpipe and when i rev it pretty good a nice cloud comes out but other than that it is not to bad smoking wise during idle.
Old 09-20-2009, 08:41 AM
JMuse84's Avatar
Pull of your cylinder head, water in the exhaust is never good. Blown head gasket or cracked head
Old 09-20-2009, 07:54 PM
so NOW you tell us there's water comin out the tailpipe?
I was trying to be optimistic.
Pull the head
Old 09-21-2009, 06:29 AM
Derf --
This one is starting to look like a basket case to me. Hopefully its just a bad gasket, but, I dunno .....
Old 09-21-2009, 06:47 PM
PdPuNOme's Avatar
I am going to pull the head off one of these weekends. How difficult or pain in the *** is doing the head gasket on this 1.9L? i know it having a timing chain eases the pain a bit.
Old 09-22-2009, 09:41 AM
JMuse84's Avatar
Its easy, just need common hand tools and a Harmonic balancer puller is what you'll need.Drain whats left of the coolant, drain the engine oil, remove necessary wires, remove fuel rail and set aside,(you dont have to pull the intake off to pull the head on this one) remove intake supports, removed engine belt remove, a/c compressor and set aside, remove harmonic balancer, remove oil pan and clean throughly ( back to 8mm bolts by the tranny can be a pain), removed the front timing cover and accessories that are in the way of removing it, removed timing chain assembly, remove the head, check the head and all components while you have everything apart. THOSE HEAD BOLTS ARE TORQUE TO YIELD, DO NOT BY ANY MEANS TRY TO REUSE THEM UNLESS YOU WANT TO DO THIS JOB AGAIN.
Old 09-22-2009, 03:10 PM
PdPuNOme's Avatar
Sounds good thank you
02 LW300
08-13-2015 04:11 AM
11-06-2014 09:38 AM
purplemotoman
03-16-2013 10:50 PM
2001SL1
10-23-2007 03:35 PM
Quick Reply: Overheating amongst many repairs help please
