please help on motor swap
Old 11-10-2008 | 07:23 PM
hollywood32401's Avatar
ok i have a 93 sl with awesome motor and tranny i got on a great deal and unfortunatly i recently wrecked it so i want to take my good motor and tranny out and put into a car that i found. i need to know the difference between my 93 sl and a 92 sl1 will my motor and tranny fit right in they are both manual what kind of problems will i run into also what is the diif in the 2 cars please help asap
Old 11-10-2008 | 10:55 PM
Low Saturn's Avatar
The one major difference between both engines is the crankshaft. The reluctor ring on the 92 crankshaft is in a ten degree different position than 1993-2002. So the engine will run at 10 degrees of retard. Add the fact that the 91-94 SOHC is only 85HP, the car wont be able to get out of its own way.
You might be able to get away with it if you also swap over the engine harness, PCM and and little rewiring of the interior harness.
Old 11-11-2008 | 12:15 AM
Thomas123's Avatar
I can''t totally agree with the car not being able to get out of its own way with an 85 hp engine, though it''s nicer to have more hp. My roommate''s 1990 Honda Civic has a 90 hp engine, and has fine acceleration, and is quite fast if gears are shifted properly. If shifted for economy, of course, don''t expect to be able to get a lot of response by gunning it.
Also, my 1951 Chevrolet, which I''ve owned for over 10 years now, has a 90 hp inline 6 (OHV) engine. It can''t squeel the tires, but has excellent low-end torque and hill climbing capabilities, and gets up to speed in a reasonable amount of time. On flat land it''s quite nice. When properly tuned, the car can easily handle saner freeway speeds (anything at or under 65), though it can go as fast as 100 on flat land. The car''s shipping weight (no fluids) is 3150 lbs., which, amazingly, is actually lighter than the shipping weight of a 2002 Dodge Stratus (a much smaller car), which weighs in at 3220 (shipping).
...So an 85 hp engine might not be the race winner, but you can have a fairly good time with it in a light weight Saturn. If it has the same pep as my roommate''s 1990 Honda, you''ll be able to do plenty of tire squeeling with it, too, though if you want to enjoy your car for a long time, I recommend not doing that.
Old 11-11-2008 | 09:51 AM
Low Saturn's Avatar
My statement about that was more about how an 85hp engine thats running with incompatable electronics is going to have performance issues.
Old 11-11-2008 | 06:31 PM
Thomas123's Avatar
Ah, yes.....especially with 10 degrees difference in timing. Just changing the timing a few degrees can make or break some cars.
lechateau
04-29-2014 09:49 PM
adamglover29
02-07-2013 07:38 PM
Rambo-SC2
06-20-2010 09:33 PM
scbatteringram
04-23-2007 12:09 AM
