Power Window question
I've got a '97 SC2 coupe (I wasn't sure if I should post this here or not seeing how I don't have a 3-door).
Anyway, the power windows work - most of the time.
However, sometimes they'll go down but won't go back up again. I find if I shut the ignition off and then back on, they're okay. Except I'd really like them to work all the time.
I figure I'll lubricate the tracks, but is there anything else I should check?
Thanks,
Larry
'97 SC2
Thanks,
Larry
'97 SC2
Start by removing the outter door panel and lubricating the tracks and gear. You also might need to remove the switch pod, open it up and clean the electrical contacts. If those two things dont work, replacement of the window regulator/motor assembly might be necessary.
TODDHENN
10-09-2008 06:01 PM
