Replacing Evaporator core on Whitey...............
Old 06-12-2024 | 10:18 PM
Umm, I don't think you need to strip the column to replace the evaporator core. drop, maybe . Even if you drink Maxwell House.
What else are you doing in addition to the evaporator core?
Please do share with the rest of the class.
Old 06-13-2024 | 03:56 AM
Dude's Avatar
LOL! not yet..
Old 06-13-2024 | 03:57 AM
Dude's Avatar
had to drop the colum.........heater core while in there, both from Rock Auto, cheap!
Wouldn't wish this job on anybody.......
Old 06-14-2024 | 03:50 AM
Dude's Avatar
gotta remove colum covers, Module finally out.
Old 06-14-2024 | 03:51 AM
Dude's Avatar
On the deck...........
Old 06-14-2024 | 11:00 AM
Bravo, sir bravo.
Old 06-14-2024 | 11:02 PM
Ahh, the first piece installed in the interior. Good plan Saturn! Not…..
Old 06-15-2024 | 06:00 AM
Dude's Avatar
Literally would not do this for a pay job.
Old 06-23-2024 | 07:50 PM
Dude's Avatar
Ok, false indication from sniffer, discovered the fan will give false indication, they say to run the AC turn off fan and check at drain hose!
I checked Goldie which has no leaks w/sniffer got a false indication.
on tear down of Whitey I discovered a loose bolt on TXV......was almost positive I did not loosen bolt, discovered bottom TXV bolt finger tight w/baby 1/4 ratchet!
Pushed on as I had interior all out.......
So I replaced TXV and Orings
Vac'd system down checked tdy it held for 24 hrs!!
Only reason I mocked up system w/original evap w/new TXV was to conform results of a 150 psi pressure test, the evap passed!
1st Four seasons evap does not look correct...........block the TXV mounts on protrudes out of the HVAC module 2 inches, I do not believe in bending pipes on a new Evap.........sent back to Rock Auto
2nd replacement, different vendor also 4 seasons, same problem, send an inquiry to their product support system saturday
I refuse to put in the 20 year old evap because of all this insane work to replace it.
Will advise.want no one else to go thru this.
Old 06-23-2024 | 09:59 PM
grcauto8453's Avatar
100 bucks an hour?
Quick Reply: Replacing Evaporator core on Whitey...............
