Saturn sl2 95 manual auto PCM computer help
Old 10-06-2010 | 07:14 PM
Ramos617's Avatar
Default Saturn sl2 95 manual auto PCM computer help
Ok I have an 1995 Saturn sl2 stick shift and I had an auto matic PCM/ecu from same year same model car dohc jus like mine but for an auto and I put it on and it makes my car run much better smoother but it has the check engine light on because of no transmission input of course and the shift up light but my question is why does it run better with the auto PCM/ecu ???
Old 10-07-2010 | 03:16 AM
Most probably the reason you changed it because there was something wrong with the origninal that affected how the engine ran.
or
you got lucky
or
magic?
Old 10-07-2010 | 10:27 PM
prob because the pcm, deprived of auto tranny input, is in some closed loop limp mode that happens to be better than he closed loop control you were getting with the proper PCM in the car
MikeM
10-20-2014 10:44 AM
Hart010
Engine & Internal
12-23-2011 12:01 AM
cathryncay
07-13-2009 09:14 PM
Racer93
08-04-2008 10:48 PM
armedgentleman
06-12-2008 10:44 AM
