SC2 Front Coil Spring
The driver's side front coil spring on my 01 sc2 just snapped. Is there an easy way to replace this, or is it so complicated that I would need to have a mechanic do it? Also, if I DO take it to a mechanic, is it that big of a job where it would be pretty damn expensive to have replaced?
I've already got the coil springs priced & a compressor rental priced, just wondering if I should just let a mechanic do it, or spend the $120 for parts & compressor and do it myself. By myself, I mean my dad.
Thanks for any help you can provide.
What he is referring to is a type of wrecking yard that allows you to remove the part you need from their fleet(?) of wrecked vehicles. Usually much cheaper than a traditional wrecking yard, where the parts have already been removed and cataloged ... and definitely cheaper than the local parts houses
HitchAnything
Member Group And Special Buys
03-14-2014 12:18 AM
