sl2 acceleration problems
I have a 1993 SL2 which has a 5 speed manual tranny in it.The problem is, the car doesn't accelerate like it should. When I floor the gas, the car crawls no matter what gear I have it in. When I initially hit the gas I can feel the car go like it should but shortly thereafter it's like it loses all power .Other symptoms are when I hit 3500 rpm 's the car starts buckling and shaking. Also, when I go up a hill I lose all acceleration and power. If the hill where big/steep enough I wouldn't make it up it. The car refuses to go up a hill even in first gear. I've been told it could be a fuel system problem like a bad filter or pump. I've also been told it could be faulty vacuum lines or a plugged catalytic converter. I just want to see if anyone here has any ideas before I start replacing everything. Thanks.
Edited by: delorean004
Yes, turned out to be a clogged cat. I pulled it off and the car flew with no problems at all. Very speedy little car! I was surprised by the actual acceleration. So I just had a local garage weld a new on in and now it runs great. Thanks for the help.
