Sluggish electric locks
Old 04-30-2007 | 01:23 PM
herbie7698's Avatar
I have a 2001 SL2 and the electric door locks all seem to be very sluggish, as in not wanting to lock. Ithink it's strange that they all have the same problem.
When I push the lock button on the inside of the drivers door and all of the locks make motor type noise but don't actually move the lock buttons to the locked position. If I lock them manually the unlock feature seems to work ok. Is this a known problem, and if so is there a fix? I have not taken anything apart yet so I don't know the conditions inside the doors.
Old 04-30-2007 | 02:41 PM
ducky's Avatar
You're right that all four door locks act the same so I would remove the main door LOCK/UNLOCK switch and examine it closely for debris or corrosion that would affect power to all the lock solenoids. Either this switch is worn,pitted, or oxidizedfrom so many years of use or the other common tie-in would be the grounds for each solenoid. I'd pop the main switch and disassemble it if possible to examine the contacts, replacethe switchif necessary.
Jaypurce
05-09-2015 12:35 AM
margorita03
07-14-2011 07:40 PM
Cloud323
08-10-2010 08:28 PM
harlowcl
07-12-2010 06:53 PM
nome_man
07-01-2007 01:29 PM
