starting issue 97 sl2
Old 12-26-2008 | 12:04 AM
gixxersac's Avatar
The car wont turn over, all power works. Im able to start the car by push starting it and also arcing the two leads on the starter. I replaced the starter-relay under the dash, bypassed the clutch saftey switch car still wont start/turn over. any ideas??
Old 12-26-2008 | 01:30 PM
Gixxersac ... Check on each of these items:
Underhood Junction Block IGN3 fuse 30amp.
RKE module (if remote keyless entry is present)
Defective ignition switch
Good luck with your search ...
Old 12-28-2008 | 08:43 PM
RC1488's Avatar
Define turn over. It wont crank? Or it will crank but not start up.
Cranks but doesnt start:
The ''97 year has a bad check valve in the pump. This allows pressure to fall when the car is shut off at the fuel rail. Easy fix. Put the key in RUN for 2 seconds untill the Humm of the fuel pump stops. Then start the car. Should start right up.
Does not crank: Electrical issue. Either security, or something with the ignition wiring.
chblanx
06-07-2012 06:11 PM
Hbal
05-11-2011 07:43 AM
masterm6
03-30-2011 12:59 AM
allen405
04-08-2007 12:08 PM
mrtigger
10-30-2005 02:29 PM
