Swapping a DOHC for a SOHC Engine?
Does anyone know if I can swap a 94 DOHC 1.9 engine from an automatic to a 95 SOHC 1.9 with a manual transmission? I know I need to change the PCM and instrument cluster, but I am not sure about the wiring harness which appears to be the same.
I believe 94 had a vacuum EGR whereas 95 had an electrically actuated, EGR.
Additionally, I believe the DOHC PCM you'll need will be looking for an MP3 transmission and may not like the MP2 it sees from the SOHC...
www.saturnwiki.net
In short, anything can be done...it's all in the details
www.saturnwiki.net
