valve cover hose
Old 08-10-2007 | 12:05 AM
5inchdrop's Avatar
what does the hose from the valve cover to the intake manifold do? can i block both sides of this off with breathers?
Old 08-10-2007 | 10:13 PM
It's part of the PCV system, and yes you can.
Old 09-14-2007 | 07:21 PM
5inchdrop's Avatar
i put breathers on both ends and the car was reving at 2500 rpm. so i guess u cant.
Old 09-14-2007 | 08:36 PM
I guess you have something other going on. I've had them on mine for years
Old 09-14-2007 | 09:04 PM
Low Saturn's Avatar
No, you cant.
5inchdrop said in his post that its the tube going from the cam cover to the intake MANIFOLD, not the intake TUBE. Removing the tube from the PCV line will cause a massive vacuum leak. The other tube that connects to the intake tube is not under vacuum and can be replaced with a breather.
Old 09-14-2007 | 11:15 PM
sorry.............mybad pictured the wrong picture, but now he knows you can't let manafold vacuum go to the atmosphere
Old 09-16-2007 | 03:12 PM
5inchdrop's Avatar
gotcha. thanx guys.
trysten
06-16-2008 11:47 AM
gbelous
Engine & Internal
06-03-2007 01:51 PM
hartman
04-07-2007 02:50 PM
mjdjlh2000
03-23-2006 02:26 PM
wspeed6
03-14-2006 08:22 PM
