Vibrations when going up hill and turning to the left
Old 08-03-2013 | 09:31 AM
Front wheel drive cars exhibit vibrations from the front of the car by in large due to worn out CV joints. The half shaft has 2 of them and loading (like climbing hills) and turning (which is what a cv joint allows you to do) will give direction dependent vibrations pretty much as a rule.
Changing them is shade tree mechanics level and requires an alignment when done. Of course having tools, a jack and a place to work helps to. Cheap to buy cars are not nescissarily Cheap to Run cars.
Rebuilt half shafts are generally available at auto-parts stores at a reasonable price.
Old 08-04-2013 | 03:38 PM
skooter's Avatar
Oriellys sold me a driver's side axle for $59 (requires $75 core charge) You can test for a bad axle by driving the car in reverse with the steerring wheel turned. It will make a grinding noise.
4x4Jeep
03-07-2014 11:47 PM
uncljohn
Saturn Relay
10-23-2013 09:32 AM
stacy1182
06-28-2012 04:53 PM
bucky katt
09-01-2009 06:14 PM
torqueaddict
01-07-2006 10:48 AM
