weird oil leak...??? 95 sl2
Old 01-24-2013 | 06:20 PM
91esgt-sl2's Avatar
I think I'll install a new fuel filter.
  #22
Old 01-25-2013 | 03:23 AM
91esgt-sl2's Avatar
No. It has not started once. i apologize....
  #23
Old 01-25-2013 | 03:55 PM
91esgt-sl2's Avatar
I plugged in my new fuel pressure tester.. It reads zero... While in the "ON" position... I crank it over.... Zero.... But I thought I hear the fuel pump.... It's a little buzz sound for like 2 seconds.... I don't have a fuel leak anywhere I can see. It has 1/2 to 3/4 a tank. Not even a drop of fuel on the schrader valve. Or anywhere.
  #24
Old 01-25-2013 | 06:01 PM
the sound you are hearing is the fuel pump relay engaging for several seconds to prime the line to appropriate pressure before the car is started. If there is not a drop of fuel from depressing the schraeder valve either fuel filter is plugged (not likely to happen from an accident), there is a wiring issue to/from the fuel pump, or the pump is bad, the fuel pump relay is bad, the fuel pump fuse is blown, or there is a leak (or something I forgot)
That's my 2 cents -- someone else please chime in
  #25
Old 02-03-2013 | 03:32 AM
mrpontiac66's Avatar
Correct me if I'm wrong gentlemen but if the Engine coolant temperature sensor, with the plastic end is cracked, or not functional can't that cause the no start issue as well?? I seem to remember replacing this on my 1998 SL2 after checking the crank position sensor, ignition control module and coils, and everything checking out just fine.
  #26
Old 02-03-2013 | 07:06 AM
Read the sticky ETCS posted in the General forum.
  #27
Old 02-03-2013 | 11:56 PM
indeed can be the case, but not likely to have failed during the accident...if it is the original it needs replacing. Anything is possible.
But when a fuel pressure reading comes back zero, me leans towards fuel system issue.
83cressy
02-28-2009 10:21 PM
trysten
04-29-2008 02:42 PM
NFGrocks1028
08-16-2007 01:56 AM
96_SC2
05-25-2007 05:36 PM
nate54
07-12-2006 01:08 AM
