When A/C stops cooling, the coolant temp gauge goes up. What's causing what?
Old 05-27-2009 | 11:27 PM
Genetic,
When you are in town and the A/C IS working, does the temp gauge climb, or does it stay put (a bit below 1/2 tick I'm guessing)?
If the temp gauge stays put with A/C on in traffic, the electric cooling fan is likely ok. It is quite normal for the temp gauge to rise on the S cars to what seems to be a scary looking level near the red-- however, the electric cooling fan kicks in and cools it back down.
If this was not occurring in your case, you'd likely be overheating in traffic with the A/C off---but you have not indicated this as an issue.
Can you confirm the above?
If so, sounds more like the A/C clutch is disengaging........
Old 05-30-2009 | 10:11 AM
genetic's Avatar
Resolution: Cooling fan motor was bad. Assembly replaced and now A/C is back to "colder than a mother-in-law's kiss."
Normally (and now) the coolant temp gauge is just above the 1/4 mark. I could never pinpoint which happened first: temp gauge spiking or A/C cutting out.
Old 05-30-2009 | 12:16 PM
Well, looks like that problem has been put to bed - glad your ride is back to par.
Frankly, I'm becoming a bit put off with the brand of electric motor Saturn chooses to install -- seems that they fail a bit more often than they should -- or maybe I'm just getting old and grumpy ....
Old 05-30-2009 | 07:30 PM
wow, I wouldn't have thought the increase in engine temp towards overheating would trigger the A/C to cut out....guess some one was thinking when they programmed the PCM....
Nice one, OA.....
___________
Glad to hear you are again one with your mother in law in a icy kinda way
Quadcouper
02-02-2014 05:13 PM
spinrb8
02-17-2013 11:24 PM
brags
07-03-2010 12:48 AM
rabobanks
07-07-2008 10:10 AM
gs69350
06-28-2007 09:04 PM
