wire diagram for 2000 SL, trunk harness
Old 05-16-2008 | 12:57 AM
mjmeredith's Avatar
I need to know what colors go where for the 8 wire harness in the trunk upper wheel well, driver side near the trunk hinge.
The gray, orange/black, and black wires broke off, so the trunk light and trunk open dashboard light do not work. I was able to pull out the prongs and solder the wires back on, but I do not know which order to put them back in....
Any help would be greatly appreciated.
Thanks
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old 05-16-2008 | 10:58 PM
Low Saturn's Avatar
Here ya go.
On the connector, there should be tiny markings showing the letter designation of each cavity.
A
BRN
IPFB - License - L
B
BLK
Left Rear Ground Splice Pack - License Lamp Ground - L
C
BRN
IPFB - License Lamp - R
D
BLK
Left Rear Ground Splice Pack - License Lamp Ground - R
E
BLK
Left Rear Ground Splice Pack - Ground Terminal
F
RED/BLK
IPFB - Cargo Lamp Switch
G
GRY
IPFB - Decklid Release Solenoid
H
BLK
Left Rear Ground Splice Pack - Decklid Release Solenoid Ground
Old 05-22-2008 | 10:19 AM
mjmeredith's Avatar
Thanks Mike,
The trunk light works again. The trunk open indicator does not light up?? I checked all of the fuses, but I will have to try and diagnose this further.
-Mark
< =text/>
urchinTracker();
Old 05-22-2008 | 10:31 AM
Low Saturn's Avatar
I believe the trunk open indicator is only for the wagons.
Old 05-22-2008 | 03:06 PM
mjmeredith's Avatar
It used to show on the console, lower right, under the tach.
-Mark
< =text/>
urchinTracker();
Old 05-22-2008 | 05:23 PM
Low Saturn's Avatar
Are you the original owner?
Old 05-23-2008 | 10:26 AM
mjmeredith's Avatar
Yes, I am the original owner, 200,000 miles
I was wondering if the bulb burned out about the same time the wires broke?
The back light for the mileage burned out, but for this year's model there is not just a bulb that can be replaced. So I don't know if this is the same for the trunk indicator? the up-shift and change oil lights still work, which are next to the trunk indicator.
-Mark
< =text/>
urchinTracker();
Old 05-23-2008 | 03:36 PM
95_sl1's Avatar
the trunk open light does have its own bulb and idk about the 00-02 but on the 95 the trunk open light only works on the wagons. but i have looked at some other gauges at the junk yard and there are some different ones. i saw one that was a 96-99 with a digital odometer and a low fuel light instead of a shift light. also from looking at my cluster there are some different lights on mine that dont even work, service light (not service engine), cat over temp, hot light on the heat gauge, dtrl,and a few others that dont work because i dont have those options , traction control, abs.... so i took the bulb out of one of these other ones when my shift light went out....
Old 05-24-2008 | 07:13 PM
mjmeredith's Avatar
I will have to see if I can get to it.I have the abs and traction control, but if I can get to it then I can probably pick up another one.
Also I have 120,000 miles not 200,000 I just can' type.
-Mark
< =text/>
urchinTracker();
jfm567
01-02-2009 06:19 PM
fosgate3
06-10-2008 11:02 AM
1994sw1
11-12-2007 03:06 PM
Zulu747
Headers, Intake, & Exhaust
06-06-2007 03:04 AM
AudioPhyle
03-14-2007 02:41 AM
