fuse to glove box compartment light
There is no power going to the light bulb in my glove box. I've pulled several of the 10amp fuses located in the interior fuse compartment with no luck. I'm wondering where the fuse would be located for the glove box light? I tested the bulb and it is good, I did a voltage check on the connection to the bulb and there is no power coming to the bulb. I'm wondering if it is a fuse or if the latch that turns the light on/off is faulty. Any help would be appreciated.
I have an 08 saturn vue xr . Thanks in advance.
I fixed it by spraying some WD 40 on the switch inside the glove box. I just had to locate the switch which at the backside of the glove box compartment. I couldn't see it but felt it with my fingers. It was pushed/stuck in all the way. Persistence pays off. Maybe this post will come to another Saturn owner's rescue.
