Gauges going crazy, Help
Hi there, I have a 2003 Vue 4cyl VTI. Recently replaced battery and alarm
system. Gauges started going crazy, Speedometer, Tach, Temp, gas,
service engine, ect... Now steering goes out, drive it for a while and it
comes back. Removed alarm, took it to the shop they said there is a draw
on the system, but no idea. Checked battery. I going to have saturn check
the alternator. It might be a ground? The mechanic said he saw a puff of
smoke coming from the harness the goes to the ignition switch, but could
not find a short. Please help
Sounds like your body control module (BCM) is on the way out...its a dealer only repair, about $ 700.00.
I have heard of corroded grounds doing some of the things you mention. Worth a try to clean up any grounds before you pronounce the BCM completely dead.
The bright spot is that a BCM won''t leave you stranded on the side of the road...but it makes almost everything else go crazy.
Thank you, can you give me an idea or post a diagram of the ground
points to check, already checked the ground from the battery to the motor.
Also is the BCM module by the alternator or the module by the braking
system?
The steering kicks back in if I turn the car off then turn it back on several
times.
Thank you
system?
times.
Thank you
Well, heck. I have to stand corrected. (Makes note about puffs of smoke and adds to troubleshooting file). Anyhow, glad you are repaired and on your way ...
Just kidding of course
To the OP: I''m glad they got to the root of the problem quickly.
Hee hee hee ... Ya got me, John
You''re right, a bad BCM shouldn''t go bad with a puff of smoke. I wonder if there''s something else going on? I only said BCM based upon the symptoms.
JustinsSaturnSL
08-09-2011 11:34 AM
