Grinding noise front drivers side of engine
Driving up hill the other day with a heavy load the vue seemed to stutter or miss. It did not seem to make any unusual sounds. I had it towed home on a flat bed and changed the air filter, fuel filter and spark plugs. I took it for a test drive and it developed a loud grinding noise from front drivers side. Seemed to be from where you fill the transaxle fluid. The power train failed, I turned off the car and then back on and power returned, I moved off the street and parked it. This is 4 cyl AWD 03 Vue. The trans. failed, and was replaced under warenty at 70,000 miles. I have about 90,000 on it now. I love this car and humbly beg advice from you, the great, wise and experienced. Help me Saturn owners, your my only hope.
Karl Jesse
Karl Jesse
Trannys are not a normal problem for any VUE unless it has a VTI trans. But it's a little tough for us to tell you what's wrong with your car via the internet. We can all sit here and guess, but that's it. I think Rube gave you solid advise.
