odometer light
Easy fix - dead bulb - bulb is $ 8.00 at the dealer...Remove IP trim - 2 screws on top & pull straight outRemove 4 hex head screws on 4 sides of IP - pull IP straight out.Remove odometer bulb - its the white one close to the bottom - remove it by turning it 1/4" counter clockwise Replace bulb...Install is reverse of removalEdited by: sw2cam
Originally Posted by RoyaL-Blue-Vue
do you by anychance know the bulb number. cause i''''d like to replace mine with a blue bulb to match my blue theme[img]smileys/smiley2.gif[/img]
refinnejm
06-13-2011 10:51 AM
