Power door lock actuator found
Old 06-17-2011 | 01:19 AM
wes0778's Avatar
Default Power door lock actuator found
I have a 2003 "plain Jane" Vue that we bought a couple of months ago. I had to go into the front passenger side door, as the panel popped loose from the bottom.
I was surprised to find a power door lock actuator, that looks factory installed, in there. This car has never been wrecked and the VIN # etched in the glass matches the car. There is no lock/unlock switch anywhere that I can find. Are the actuators installed in ALL Vues and the controls installed only on the cars where power locks are specified/purchased?
If there are actuators installed on the other 3 doors, what would I have to do to take advantage of this "found" accessory?
Old 06-17-2011 | 08:53 AM
Two questions come rapidly to mind .... is the actuator properly wired into the electrical harness inside the door, and (2)- is the harness for the door lock switch locatable? Probably have to "add" a fuse to the fuseblock to make the circuit "live" .....
Old 06-17-2011 | 05:58 PM
are they possibly already functioning as part of a keyless entry system?
Old 06-17-2011 | 11:09 PM
wes0778's Avatar
The more I think about it, the tailgate locks automatically, so I wonder if the doors are suppose to lock and unlock automatically?
I guess I need to check the fuse box under the hood to see if there is a slot for door locks.
Not that I'm aware of...
But I did buy it used, so there is no telling what has been added since 2003.
Old 06-17-2011 | 11:20 PM
Actually keyless entry was not standard by 2003. My bad
Might have been cheaper to build 1 type of door on the assembly line with all the parts in it and then hook up what the option list called for
Old 06-18-2011 | 10:56 AM
Simple experiment might give you an answer -- get in, (leave the door locks up) start the car, put it in gear and drive -- do the locks trip closed?
Second test, you've been driving with the locks locked. Stop the car, remove the key from the ignition -- do the door locks open?
Old 06-18-2011 | 06:20 PM
wes0778's Avatar
No to both questions. The tailgate is the only thing so far that locks automatically and it has to be unlocked from the outside with the key.
gotta look for fuses...
Old 06-18-2011 | 07:29 PM
Wes, good to see you posting again.
DonVue2002
11-14-2013 11:02 AM
alex_0227
07-18-2009 08:36 AM
dean_maiorano@hotmail.com
06-01-2009 05:57 AM
mflury
08-24-2008 03:47 PM
NBR_JasonB
06-18-2006 03:00 PM
