Upper trans mount
Old 09-05-2024 | 04:44 PM
Stove's Avatar
Default Upper trans mount
M 03 vue has af-33 trans. My 05 equinox has af33. They should use the same upper trans mount. My 07 torrent also has af33 trans but uses a different mount than the 05. I can see the difference on cast arm on trans mount from pics from 05 vs 07 but I cannot even find a 03 mount for sale online. I bet no one has ever changed an upper trans mount on this site?
my rig has a thud-thud kind of sound from wheelwell area. I put in new strut assy and it made no difference.
in my mind I think it is trans moving and hitting subframe. Maybe that’s just me.
Old 09-06-2024 | 07:58 AM
Do you have a sway bar? If so, check those bushings. And have you checked the lower control arm for worn bushings?
Old 09-06-2024 | 08:44 AM
Stove's Avatar
New sway bar links. New sway bar bushings. Control arm looks good. Ball joints appear tight. I’ve had 10+ equinoxes as I fix head gaskets. I am well aware of suspension issues. I unbolted outer tie rods. Nice and tight. I’d say they had been replaced.
I have no idea why mount for 05 is different than 07 as they both have same trans.
on a mildly uneven road the suv makes no noises. It takes a rough road to get the thud-thud sound.
I had to lower subframe 1-2” to get trans mount out. Subframe bushings look good.
I have mount on order.
Old 09-07-2024 | 12:18 AM
Check the top of the strut.
Old 09-24-2024 | 05:58 PM
Stove's Avatar
I put in another used strut assy and sound was exactly the same. No difference. So, I have not put in a new strut/mount. So I am still not fully convinced I am on right path.
Old 09-25-2024 | 08:21 AM
He's referring to the strut bearing on top, I think. Did you replace that?
Old 10-10-2024 | 10:01 AM
Stove's Avatar
Yes I replaced entire Strut. I gave up. Sold car. That was plan. Fix motor. Sell car. Buyer said clunk was ok.
Old 10-11-2024 | 05:02 PM
Stove's Avatar
Bought a 09 equinox yesterday. 98k miles. Thing is really really clean. NO bumps or squeaks on road. Got it due to possible head gaskets. Not a hard repair. Done a few
Old 10-12-2024 | 08:26 AM
Good luck with that Equinox. I had an 07 and kept smelling gas. Pulled up NHTSA recall information and they showed that there was a recall on certain VIN's. I called the local Chevy dealership and they said mine wasn't on the list. I told them it was doing exactly what the recall mentioned and I wanted it fixed. They refused and I called a friend of mine who's a high power attorney and I called the GM complaint line. 30 minutes after my buddy called them, they called me and wanted to know when I could bring it in. They replaced the faulty fuel pump for free! LOL One a trip back from FL with the wife, the damned ABS and TRAC lights came on. I zipped off the interstate and had the codes read at Autozone and they said it was a bad EGR valve. I drove it home like that and went to the Advance where I had once worked and asked them to run the codes. They also said EGR. I bought one and replaced it and both lights went off. I still don't understand how a faulty EGR could have tripped the ABS and TRAC lights. I traded that POS off on a Chrysler 200 and never missed a day of it.
Old 10-12-2024 | 08:41 AM
DropDead's Avatar
Guessing 4 banger?
Quick Reply: Upper trans mount
