Suspension Talk about your suspension within...
spring rates and coilovers
Old 06-11-2011 | 03:00 PM
Sleepy SL's Avatar
Exclamation spring rates and coilovers
Spring Rates:
OEM Springs: ............................ 126 lb/in Front, 129 lb/in Rear
H&R Race (1.4"F, 1.3"R):.............. 310 lb/in Front, 250 lb/in Rear
H&R Sport (1.4"F, 1.3"R):............. 205 lb/in Front, 195 lb/in Rear
Eibach Pro Kit (1.3"F, 1.1"R):........ 149 lb/in Front, 91-159 lb/in Rear
Progress Group (1.8"):................. 200 lb/in Front, 170 lb/in Rear
Progress Group (1.3"):................. 156 lb/in Front, 150 lb/in Rear
Sprint (2.0"):............................. 200 lb/in Front, 140 lb/in Rear
Sprint Extreme(2.5"): .................. 200 lb/in Front, 140 lb/in Rear
Suspension Techniques (1.4"):...... 157 lb/in Front, 109-155 lb/in Rear
Struts:
KYB GR-2 front: 30% stiffer than stock
KYB GR-2 rear: same as stock
Agility Coilover - Saturn S-Series - 1991-2002
  • Forged 6061 aluminum upper mount.
  • Pillowball upper mounts are standard.
  • Each shock absorber is outfitted with a rigid 42mm internal steel piston and resin piston ring through a high performance monotube damper.
  • Each coilover unit is adjustable through 32 levels of damping for track/street conditions.
  • Separate lower bracket height adjustability prevents the need to adjust the spring perch.
  • Springs are cold bent using silicon chrome steel with a tensile strength of 2000N/mm.
  • High quality T6061 aluminium alloy used for all adjustment locks
  • The forged aluminum shock body is anodized to prevent corrosion and surface oxidation.
  • 1 year warranty against manufacturer defects and failure.
COILOVERS
Product Name
8-Way Rebound Adjustable Coilovers
Brand
AMR Engineering
Description
Assembled here in the USA, our custom coilover systems are designed to meet your needs. Our coilovers feature a mono-tube design, and machined using the latest tooling and equipment. Our machine work is simply outstanding, and we take great pride in the quality of our work. These are available rebound adjustable only and feature a distinct 8 click design. Our coilovers also allow you to adjust both preload and shock length. So adjusting both ride height and preload is fast, and simple. With the ability to adjust shock length you maintain your shock travel, and lower your car without sacrificing too much ride quality. Our saturn coilovers are the only ones available with front and rear camber plates. These also include spherical bearings in each corner. These are meant to be the last coilovers you will ever need for your vehicle and come with a lifetime warranty on both the shock and spring. Speak to us today about getting a set made specifically for you and your driving needs. No more guessing games, leave it to us, and we guarentee you will love the ride quality and performance of our product.
I AM NOT A VENDOR FOR ANY OF THESE PRODUCTS just some good inf o if someone didnt know
figured I would contribute a possible sticky
Old 09-01-2011 | 08:57 PM
Good post, keep them coming. Post ION info also.
RjION
Suspension
01-22-2012 07:13 AM
Mears
04-09-2011 11:35 PM
teresadf
04-05-2010 07:15 PM
Zulu747
Suspension
05-12-2008 12:32 PM
JC316
02-29-2008 11:44 PM
